- Nov 17, 2017
- 1,525
29.5º from 90º is 60.5º not 59.5º
The tool that I took the picture with is a standard 60* tool, I am actually using a Mesa Tools threading tool with a carbide insert. After I reset the compound with the jig that Dave Pane showed it cut a nice 60* thread.If you want to use the compound then it should be feeding at the same angle, to the centerline of the work, as one half of the thread angle. Different machine makers put their degree scales with the angle reading either from the centerline or off perpendicular to the centerline (ex; 30 degrees either side of perpendicular. Dave Pane shows a sure fire way to make sure your set up at the correct angle.
I have the compound removed from my lathe and the QCTP mounted direct to the cross slide to increase rigidity this means I must cut threads by feeding the cross slide. With a good sharp tool this presents no issues and I actually find I get better threads with the set up I have. Cross slide seems to be the weak link on a lot of lathes.
I cant see the insert tool you have close enough to tell so forgive me for asking, is that a specific threading insert or a standard 60* insert?
Just curious,should you not use a standard 60* insert tool to cut threads?The tool that I took the picture with is a standard 60* tool, I am actually using a Mesa Tools threading tool with a carbide insert. After I reset the compound with the jig that Dave Pane showed it cut a nice 60* thread.
Thanks for the help.
Is there some secret to getting clean cuts? My lathe recommends 125 RPM and lubricant. They turn out decent but require some clean up with a wire brush and file. I am not taking deep cuts.If you are talking about the equilateral triangle inserts, they will work but you cannot thread close to a shoulder with them.
