Too bad there isn't a way to keep the brake arm from marking your nice shiney paint work? Maybe a delrin pad mounted ,like a smile, where it does all the contact?
I just realized what you actually meant... a smile... a flat curved piece under the brake handle... maybe glued to the top cover... so the brake handle moves/slides over it.... ahhh.... back to the drawing board... let me try that approach.
Oil tank installed...next will be to redo all the lines.
This is how it is supposed to all fit... this is the part I machined. Now it goes over the brass shaft from the gear... Still need to drill the 1/8" hole in the gear and pin the two parts
Yeah, now it looks better... Instructions call for the extension to be pinned with the stock shaft... but I think that I can remove the extension shaft. I will not be installing the handle. I can always screw the extension back in if needed...
Pulley installed!!
This is how the draw bar should be... the stuff you see in the hand brake is copper paste, not rust...
And this is now much I need to remove from it...
A mistake that I made was not measuring the spacer that they place at the end of the of the drawbar... I figured it was the same width as the bar... Nope... so it would not go through the hole I made on the top base, sob!! So either I turn down that spacer or I make the hole larger...
The gear is pinned with the machined part… so for practical purposes, it is now one piece…
I need to watch the videos and read the instructions again… to validate if the complete assembly is then pinned to the shaft or if it just held in place with a bolt and washer in the front of the shaft…
EDIT: This answers my question...
Only insert a roll pin across everything IF there is no key slot in the leadscrew... mine has the key slot... so the assembly is only held in place, against the motor gear, by the bolt and washer that goes in front. Got it!
That tap appears to be a bottoming tap. It is going to be hard to start. You might consider getting a tap with a longer taper. (Tapered chamfer, or plug chamfer.) Of course if this is all fixtured, like in a lathe, might be ok. A tapered chamfer tap is a whole lot easier to start.
