B
bvd1940
Forum Guest
Register Today
That looks like a good option and simple, Thanks Jim
Bill
Your BOB isn't designed to be panel/chassis mounted that's the issue. I would mount it internally where it makes the most sense, then run a cable from there over to a panel mounted coupler for the USB and DB25. That gets you through your cabinet to the outside world, just connect a cable from there to your computer.
For the USB I would use something like this so I could just drill/punch a round panel hole for it http://www.amazon.com/Switchcraft-E...sbs_147_9?ie=UTF8&refRID=0C4G79KJHFJ19AY3XF04
Go to Digikey's web site, search on DB25 and have a look at the "housings" here's an example that might work for you. http://www.digikey.com/product-detail/en/205165-1/1122-1149-MIL/132220
When building vacuum tube guitar amps you have to be quite careful about the grounding scheme and AC power routing so that you don't have 60 cycle AC hum coming out the speakers. You can induce AC hum by routing AC power too close to signal wires or components. Poor placement of the transformers in the chassis. You can induce AC hum by poor chassis grounding schemes grounding signal carrying components down stream of large current AC power sources, where the chassis has become a ground wire basically.
There are a number of best practices, twisting AC pos/neg wires together for example so that they cross each other a few times per inch, a cordless drill is a good tool for this. Here's another tip, discover "top coat" wire, its still flexible and comes on a spool but has a top coat of tin so that if you bend it into a shape it holds that shape. With Teflon insulated wire the top coat is less effective but helpful. You can find this type of wire for sale by suppliers who cater to guitar/amp builders. Shoving twisted pair AC power wires into the corner of the chassis e.g. the corner of the chassis provides a bit of shielding. Where you have to cross an AC power source with a signal wire cross it at a right angle vs say running them parallel to each other.
Many have probably hear a guitar amp humming loudly but its entirely possible to build a 100 watt monster amp with zero hum. On my first successful build I wasn't hearing any hum at all, turned the amp up to like 8 and all I heard was some white noise hiss, thinking something was wrong I hit a cord and about blew my ear drums out. Don't let the 100 watts fool you, for a tube amp that is stadium concert loud as all hell.
Possibly overkill for wiring up a CNC control box but proper layout of components with some logical thought to separating large AC currents from small, or AC from DC is a cheap way of avoiding glitchiness.
Well I got back to the shop FINALLY!! and made some progress on the electrical s BUT still waiting on the plugs for the stepper to panel cables.View attachment 106272 View attachment 106273 View attachment 106272 View attachment 106273 View attachment 106276
Here are a few pics showing what I have been up to. I said SLOWLY on this build but did not think it would be this slow.
I know I would forget sumptin, what amps you put in yours??? I will have to get on fleabay and find some online fuse holders.Looking good Bill!
One recommendation I would make would be to put a fast blow fuse or breaker between the power supply and driver. I stalled one of my 1600oz steppers for a half second but it was enough to blow some of the rectifier diodes on the driver board.
Jay
I did get the panel mounted on the wall today and took the plugs in the panel and am direct wiring to the stepper motors and will put a plugin at the motors. Got the cooling fans in (1 sucking 1 blowing) also and test powered the panel & guess what no sparks,smoke and all lights came up green yeaaaa!
Thanks for the heads up on the fuse/breaker I will go hunting for ? amp breaker/fuse.
Bill
