When I first got my grinder I planned on a green silicon carbide for carbide tools and a white aluminum oxide for HSS. The white wheel is very difficult to find. Camel makes them in white so I ordered 2. They would not fit. The mounting bolts heads for the wheel hit the inside diameter of the wheel. They would need to be mounted on a lathe and a diamond tipped boring bar used to open up the inside diameter of the wheel. That's why I went with CBN and diamond wheels from Shars. They run about $100.00 each. They have countersunk holes for the mount bolts on the CBN and non countersunk holes on the diamond wheel. I used shcs on the diamond wheel and countersunk flat head bolts on the CBN wheel. I snugged up the bolts on both wheels and used a dial indicator to get less than .001" or better tir on the wheels and tightened them down. I can easily balance a nickle on edge while the grinder is running and it will stay there without moving. This may be the wrong procedure but it works. I may have gotten a defective set of the Camel white wheels, but I wasn't about to try for another set. I am not recommending you do what I have done, just trying to give some information. Here are the specs for the Shars wheels:
6x1 D6A2C Diamond Plain Cup Wheel
SKU 505-2220
Wheel Type 6A2C
Wheel Shape straight cup
diameter 6
Wheel Thickness 3/4
Hole 1-1/4
Diamond Depth 1/16
Rim Width 1
Grit 150
Concentration 75
Bonding resin
Coating uncoated
Core Material bar stock aluminum
Dia: 6"
Thickness: 1/16"
Product Spotlight
For carbide tool grinders in 6" diameter
Diamonds on outer rim
Bolt holes on countersink wrong- not countersunk
catalog page 187
6x1 D6A2C CBN Plain Cup Wheel
SKU 504-2220
3
Wheel Type 6A2C
diameter 6
Wheel Thickness 3/4
Hole 1-1/4
Diamond Depth 1/16
Rim Width 1
Grit 150
Concentration 75
Bonding resin
Coating uncoated
Dia: 6"
Thickness: 1/16"
Hole: 1-1/4"
Depth: 1"
Grit: 150
Concentration: 75%
And the Camel grinding wheels:
CGW Type 50 White AO Grinding Wheel And Silicon Carbide Grinding Wheels
800-447-4248
UPC #: 34948
Name: White Aluminium Oxide
Wheel
Opening Diameter: 6″
Arbor Hole Size: 4″
Height: 1″
Grit: 46 (Medium)
Grade: K (Medium)
Bond: V (Vitrified)
Specification: WA-46K-V
Max Operating Speed: 3,450 RPM
Colour: White
Material: Aluminium Oxide
Type: 50 – Plate mount wheel
Roy
