This tube I'll be brazing on is 1/2" thick.
Here's a better view from the back end.
You can see the crack at the bottom of the rectangular slot heading off to the right. It goes exactly half way around. So this jaw is being held on by a half-circle of 1/2" thick casting. That's why it didn't break off entirely I guess. It's a pretty heavy duty vice. I think it's still worth trying to rebuild. But yeah I'll be able to grind a really deep vee-groove in this. There's a lot of material there to braze to.
Don't worry, it's cheap as far as that stuff goes. It's useful for many repair processes, so you might even find it at your local hardware store.
I'll look around and see what I can find. I'll probably need to order some. I live in a rural area where there aren't too many decent hardware stores around anymore. There used to be, but they all closed up. Sadly.
I would like to try to TIG braze this just for the learning experience. But we'll see how it goes. If I get in the mood to braze before I get the proper TIG rods I might just braze it up with gas.
Preheat the part by building a brick "oven" around it to contain the heat. This will also slow cooling after, so win!
I actually have a blacksmith forge. I wouldn't heat it up too much. But I could certainly warm it up in there quick enough.
I also have a couple old propane cooking grills that I use for heating things up. I don't use propane on those anymore, I just burn scrap wood in them when I need to heat something up. They have the nice cast cover that holds the heat in pretty well. Like others have said, you don't need to get it too hot. In fact, the idea is not to overheat it. 300 to 500 degrees F should be plenty.
Not sure when I'll do this welding. I'll grind the vee-groove first. I do projects around here a little bit at a time. That's just how I work. I'm usually doing 10 things at once. So I do a little bit on each thing. So it may take this project a week to get completely welded.
