It turns out there is welding /brazing used in this project after all...
I had to braze extra weight to the weight I previously ground down. Also I opened up the groove they ride in by half mm (on diameter) and they fit very nicely.
This is the bottom side so it will be invisible ant it was ground down to just add 2g to the weight.
Interestingly, with a grub screw each weight came to almost exactly 50 grams. I suspect that's how they designed it
This wheel hub and weights must be the most complex part in the entire machine. Having spent so much time making an extra I'm not surprised so much by high prices they want.
