I've been intending to make a couple of additional surface grinder arbors for years as my surface grinder came with just one and if I take a wheel off it requires rebalancing.
The arbors have a 90mm diameter (almost 4in) collar on the back. This collar in addition to providing something for the wheel paper to push against have a face grooved dovetail and 3 weights with grub screws to balance the wheel.
The problem is that to make the arbors from single chunk of steel I would have to start with a 90mm+ diameter bar(almost 4in) just to turn 90% of it to around 25mm(1in).
So I have an idea to tig(or mig) weld 30mm diameter(~1 and quarter in) bar to the 95mm bar and machine it from there.
I thought to ask here first if this is a bad idea. There is a taper on the inside of the arbor so I would have to ensure the weld is as thick as the resulting material on the finished part. I can chamfer the smaller bar a lot and do multiple passes to fill it with steel.
I plan to use standard mild steel, and a standard mild steel welding rod/wire. I plan to wire wheel clean it between passes.
What do you think? Is welding it worth it? This arbor has to be super precise. Am I likely to have some internal stresses in the part that may reveal themselves when I cut the taper near the end? Is mild steel a bad material choice perhaps? I don't have any case hardening compound available to me so it will stay soft.
