Weird, Scary, Power Gizmo-thingy
nothing says safety like tie wire on a capacitor bank!
A friend of mine had a folding battery charger that made that thing look safe. It consisted of a two-wire line cord and plug, two diodes, a capacitor, and a set of jumper cables, all connected by bits of stranded wire. No chassis or case. He kept it in a bag and laid it out on the ground when he used it.
If that were manufactured today it would have like 14 government mandated warning stickers.
You mean the charger my buddy made? I wouldn't apply the word "manufactured" to it (or to the device at the top of this thread). I don't think I adequately described my buddy's device. There was *no insulation* on any of the connections. It *had* to be spread out carefully to work: otherwise it would have caught fire. I *think* that he used a polarized plug and made sure that the negative terminal connected to the neutral, but I'm not sure. I never used it and stayed well clear when he was.
That sounds like a good plan , John. Unfortunately, I have seen similar contraptions. Best to back away quickly when you meet one.
Home made fence charger???
See if it will blow up watermelons...
It looks like a power supply and with dual voltage output. That larger transformer has a very serious secondary winding which would indicate some extremely high current low voltage output. And that component to the left of the Variac looks like a repurposed high voltage transformer from the earlier TV’s with CRT’s. And this thing also has a diode multiplier suggesting high voltage…Good Luck, Dave.
Trying to understand what this gizmo is from the pictures is like trying to understand a Picasso.
