I would guess from the insulators on the large capacitor and the three series diodes that there is some high voltage involved, possibly in the kv range. There are bleeder resistor strings across the capacitors which should safely discharge them in a few seconds to minutes, depending on the capacitance. Maybe a zapper for those pesky mosquitoes?
Not likely EDM: that wants low voltage and high current. This is a high-voltage supply. The three diodes are part of a voltage multiplier. What is the device on the left front next to the variac?
The missus bought an entire wall of electrical/electronic junque (again) at an estate sale this weekend.
This gizmo is just plain scary. Any volunteers for plugging it in? View attachment 114977View attachment 114978View attachment 114979
There is a bunch of cool stuff too. I scored some tools and also came away with a new 5C indexer.
Several vintage Variacs, couple of lasers, and a bunch of laser mounting accessories.
Some real oddball stuff.
It looks like it could be EDM Or maybe A defibulator I don't understand why the high tension coil on there, with that much capacitance it will light your fire
I was just thinking that the variac and maybe a capacitor and other stuff might be used to make a homemade edm like the one I linked to in another thread.
