- Jun 12, 2014
- 5,127
If that is the case, you could get an inexpensive 1/4Hp VFD for the drive, but at the end of the day may be simpler and not much more just to replace it with a single phase 120VAC drive. The micro VFD's are quite small, and you could run everything off of 120VAC if you wanted.You could put both VFDs in the same cabinet to prevent chips from getting into them. Sealed VFD's are a bit more expensive.
