- Dec 22, 2015
- 561
I'm new to milling and just getting some hours in with the new mill. I've squared up a block and my el cheapo vise that came with the mill and things were looking good until a few hrs ago. I finished using a 3/4" end mill to face 4 sides of a 1 1/2" thick mild steel block that was 3" wide and 6" long and figured I would use the end mill to side mill the ends of the block, rather than try to stand it on end and get it square to the other surfaces. Started out ok but I noticed it was getting harder to cut so I stopped and checked the cutter. The bottom sides of the cutter that were below the DOC were still very sharp but the sides of the cutter that were doing the work were dull. I started taking 0.005" deep cuts and backed off to 0.002" as I progressed but dull is dull and it was obviously not getting better so I stopped.
Is this the wrong way to go about side milling and if so what is the right way?
