- Jan 28, 2020
- 211
As of yet, Sherline hasn't provided dimensions of the machined base on their website.
Here are some measurements that I took, in inches:
4400 Machined Lathe Base - 2024 series (44040)
- 26 3/8" long x 4 7/8" wide x 0.3612" thick (average, see below)
- thickness measurements, using Mitutoyo digital micrometer:
The top of the base has been machined; the bottom has not.
There is a not-threaded 0.257" diameter hole near each corner, located 1/2" from left/right edge and 1/2" from front/rear edge.
There are is a 10-32 threaded hole near each corner, located 1.0" from left/right edge, 1.0" from rear edge, and 0.97" from front edge. These might be for Rubber Feet w/screws (61100).
Machined Headstock End Mount (44020)
- 3.02" long x 3.02" wide x 2.50" thick
The base (44040) extends 1.22" to the left.
Machined Tailstock End Mount (44030)
- 2.00" long x 2.375" wide x 1.90" thick
The base (44040) extends 1.22" to the right.
The 24" Machine Lathe Base Assembly -2024 Series (44050) is 0.36" + 0.05" = 0.41" taller than my 24" Cast Lathe Base (44010). The 0.36" is the thickness of the base (44040). Note: I milled and filed the bottom of my cast base flatter, which reduced the height of my cast base by roughly 0.05".
One conclusion that I draw from they measurements is that if I decide to buy the end mounts and install them on a custom base (instead of 44040), then the custom base will need to be at least 3.02" wide by 23.935" long (26 3/8" - 1.22" - 1.22") to fit entirely under the end mounts.
