If you insist on carbide inserts and want a fine finish in junk steel like 1018 or A36 your best bet would be a negative rake tool like TNMG or CNMG, crank up the speed to at least double what would be reasonable for high speed steel take a deep enough cut to get thru the mill scale and feed at .003 to .005" for finish cut, maybe twice that for rough cut. Dial it in so your chips are tan to just turning blue, make sure you ready for the flesh melting chips, but with right speed and feed you can easily get a near mirror finish when you get just short of blue chip zone. No oil, and if you use coolant you need to consistently apply it with flood or mist, no periodic spraying as that will cause havoc with the carbide heating and cooling, so either run dry or use lots of mist or flood.
This procedure works for me. The other method that works is to use a vertical shear tool, very light feed, depth of .001" and standard HSS speeds., The shear tool will give acceptable finish but usually will not give you that burnished, almost mirror finish the above negative rake carbide method can.
michael
