Mild steel, decent finish, best shot is with with HSS tooling with positive rake............ My $.02
I think the other guys are pretty much on the level with the recommendation towards HSS; Hobbyists seem to gravitate towards carbide inserts to avoid learning how to grind a HSS tool, this situation is not so conducive to fine work, especially on lightly built machine tools, and cheaply bought inserts, especially negative rake styles. As I stated, I use MagicTap for nearly all work requiring a cutting fluid, it does make a difference, as opposed to cutting oil, to say nothing of "motor oil" that some folks swear by.Is this to be expected regardless of the type of cutting tool?
I have tried many kinds of inserts and different cutting speed but still unable to get a good finish on mild steel. Achieving it on stainless steel , brass and aluminium is super easy. I can get a better finish on mild steel by using sharper inserts designed for fine cutting but the result is still poorer than that obtained on other metals. May I know if there are things that I have missed ? The picture below shows the typical finish I get . With the same insert, the finish on stainless steel is close to mirror like.
Just a thought - it looks like you're turning down an old bolt. This is likely to be a higher tensile steel. I have often struggled to turn down threads compared with a piece of round bar. Possibly because the round bar clamps better in the chuck and reduces chatter.
It could also be that the cutting forces in the mild steel are higher than the likes of brass and aluminium and on small diameters the bar is deflecting more. As has been said a sharper cutting tool or a smaller depth of cut may help.
A mirror like finish in mild steel is probably a bit ambitious but you should be getting a smooth and consistent finish in either carbide or HSS.
Search for "HSS shear tool" and it might give you some ideas.
A shear tool will work but you wont be able to cut right up to a shoulder. The closest you will get is about half the tool width.
