- Aug 14, 2020
- 62
Just to clarify, you're calling the carriage movement the X axis and the cross slide the Y, right? I believe the "standard" is a bit different with the carriage being Z (the spindle anchors the coordinate system) and the cross slide being X: https://www.hobby-machinist.com/threads/x-y-z-on-a-lathe.44499/
It seems a bit confusing and I'm not 100% sure , but as long as we're all on the same page; what you're seeing is that the cross slide travel on the DRO isn't matching reality (as defined by your 2 calipers), correct? Can you detail what your calibration process was and also what you're test procedure was for making the cut?
Are these the same brand/type of scales that you put on the mill?
How are you tweaking the calibration numbers when you try and correct it?
Did you try setting it to 5080 and seeing if the measurements match then?
Are you getting the same wrong measurement repeatedly or is it varying?
My initial concerns are to ensure you're using the same reference point for all the measurements and to ensure that you don't have some issue with mounting or interference with the scales.
