A PC water cooling setup should be quite adequate for that. Miniature radiators, pumps, pipes, connectors readily available, mass produced and inexpensive.
Lo-Fi
Yes I have been looking at them but maybe a vintage water cooling tower instead. Also thinking of making my own centrifugal belt driven water pump.
Life has got in the way so not much progress recently.
I did get the rod journal bushings made and sized for the crankshaft.
I cut and installed a base plate for the engine.
Polished up the plate and the rods some.
This was piston day and I started off turning some aluminum down to size times two.
The pistons are 1.250 long.
Sorry I was so preoccupied at getting all the measurements just right that I forgot to take any pictures of the next operations but here are the results.
I milled a 0.312 slot 1" down into piston face and widened it out for clearance of the rod end.
I also made two wrist pin bushings and installed in the rods.
I was trying to hit a piston TDC height of 0.225 below the cylinder head surface. According to my calculations that would place the wrist pin 0.500 from the end of the piston.
The piston heights turned out 0.227 and 0.233 and that gentlemen is just fine with me. The compression ratio will be very close to 7 to 1 right at my target.
I will be adding the o-ring grooves at a later date as I find it easier to work the rest of the engine with out the drag of the rings just now.
Everything turns smoothly and fits nicely so all my worrying was for nothing.
Time to make some valves. I made seven valves today but not to have some extras as I screwed up the first three. The first one the stem was too short so I made sure that that would not happen again but I may have gone overboard with the length. At least it will make easier to grab on to when lapping The next two I just wasn't paying enough attention and made the stems diameter too small. They probably would have worked but they were too loose in the valve guides and I wouldn't be happy.
I started with a 3ft piece of 5/16" drill rod and used over half of it.
Four valves extra long shank.
I also drilled and threaded the intake and exhaust ports 5/16".
The holes even lined up with the valve cages as they should.
