If you ask 10 machinists at random, most will say that the advice in this thread is all wrong
Sometimes traditions were developed before technology interfered. The stubby screw machine drills took a long time to migrate to machinist's tool boxes.
Unless you are in a production environment any method of spotting a hole is valid, there is no right or wrong way there is only a faster or slower way.Oh good! I'm glad to know that I didn't get the "wrong" center drills since my primary application is indeed starting holes on the lathe (or maybe in the mill). I guess I'm still a little confused about the purpose or point of the spotting drill, but I think this might be in definition alone. If I had to take a guess at what "spotting" a hole means, I'd imagine it meant to start the hole in the correct location. IF that's true, one could claim (maybe?) that a center drill is a specialized type of spotting drill since it is also used for starting the hole in the correct location, namely- the center of spinning stock. Am I on track here?
If all that's true, then I'd infer that a center drill is for starting a hole specifically on a lathe, and a spotting drill is for starting a hole everywhere else. Yes?
And money.I really prefer to use no starter drill, just a 135 degree split point screw machine (stub) length drill which is stiffer, will not walk on the work, and will center itself. Starter drills are a major waste of time.
Lots of good information here, thank you.
Now I am looking for affordable spotting drills and find that 90 degrees seems to be very popular.
When would one use a 90 degree spotting drill?
David
You use a 90 degree spot drill when you want to put a 45 degree chamfer on the part and also use drill as a starter.Lots of good information here, thank you.
David
