First let me say that I think Bob's post above is an excellent summary and guideline.
For years I always used centre drills for spotting and was often not too happy with the results but just figured "that's the way it goes some times".
When this thread started I did what lots would do and googled it. My second suggestion is to forget doing a google search. I found much conflicting information.
Instead I suggest that you get a couple of spotting drills and do experiments. This is what I did and was very impressed with the improvement. I use 120° spotters for 118° drills and a large 135° stub drill for spotting all my smaller 135° stub drills.
I normally use small bits under .250" and under magnification it was easy to see the following bit wobbling around when spotting with a centre drill and how steady the bit was when using a 120°spotter.
David
David
