Hi Everyone, This is my first post.
I'm building a small home shop with the goal of being able to prototype ideas mostly within the shop. I've recently bought some equipment and made some mistakes and observations, so I'm hoping while the lessons are fresh in my mind, I can help someone ask the right questions and be happy with what they buy.
Before I got into software development 30 years ago, I was a Precision Sheet Metal Mechanic for about 6 1/2 years, and spent a good deal of that time programming CNC punch presses, and planning out production for most parts and assemblies that came through the shop. The rest of the time, I was making parts! I did spend some time on manual mills and a lathe, but not a whole lot. So I'm kind of a newbie on those.
Although there are some tools you can skimp on, I agree with everyone on here recommending to buy quality over quantity.
You're going to use these tools and machines for many years, so every time you use one of them, you'll either be glad you bought quality, or wish you had bought quality, even if it meant delaying the purchases, or delaying purchase of something else.
I have an LMS 3990 mini-mill from a project my Dad and I did a few years ago, and about a year and a half ago, I bought an LMS 7350 mini-lathe to match. I bought the mini-lathe because without overanalyzing it, I expected the capabilities of the mini-lathe to match those of the mini-mill.
I was wrong (and I should've done my homework a little better).
As soon as I opened the crate, I thought Wow! This machine is tiny! I immediately wished I had bought a bigger machine and maybe skipped buying tools that could've waited.
For me, it seems having the next size up on the lathe is more important than upsizing the mini-mill.
I'm agreeing that within reason and mostly within budget, buying the machine you really think is best for you is worth the extra cost. I'm not suggesting to always buy the bigger machine, because there are other considerations: space, power requirements (I don't have access to 220V), anticipated possible uses (estimate on the big side), if you move a lot, and of course cost, but if you can, get the right machine first, or at minimum consider how much extra it'll cost, and if you'd be better off delaying purchase of something else so you can start with the right base machine.
I like the LMS 7350 mini-lathe. It seems like one of the best in its class, but I know that in the future I'll be upsizing, and I wish I had bought the right size the first time. That size may be fine for your needs. Mini-lathes are great for the right projects, but there is better rigidity in the bigger lathes, not only in the base, but in the cross slide, etc...
I'm planning on buying or converting a mill to CNC in the coming months and will most likely upgrade the mill too.
After looking at costs of prebuilt CNC machines, I believe I'm going to end up with better bang for the buck by converting a machine myself.
I can convert my mini-mill to CNC, but I feel that in the long run, I really want a larger machine, and to be able to make faster cuts than the 3990 supports.
My immediate gauge of size is that one of the parts I'd like to make for my motorcycles is roughly 6" x 6", and with the mini-mill, I'd have to mill one half, then flip the part around and re-align, then mill the other half. I'll make other things with CNC, but that's kind of my indicator.
So, to eventually have the capacity I want in a CNC mill, if I convert my 3990, then upgrade to a bigger machine later, I'll be able to reuse the motors and the electronics/software, but the cost of the conversion kit/ballscrews for the mini-mill would mostly be lost when I sell it.
So, if I can swing it, I'm thinking in the long run it'll be better to upgrade to a larger mill first, then convert the new mill to CNC.
I'm looking at the Grizzly G0704, the PM-25MV, the LMS 6500, or (what I really want) the PM-728V.
I've read every article I could find, and watched a ton of videos comparing the machines, and the information conflicts. Mostly everyone likes the quality of the PM over Grizzly, say good things about the LMS 6500, but don't really say where it stands in terms of rigidity compared to the other 2. On one site a guy who has both says that despite the lower weight and how the column mounts to the base, the G0704 is more rigid than the PM-25 and better for CNC conversion and cutting steel.
The 6500 is interesting because it's the only one of the 3 that has a fixed column, and I'd love to know if that makes it more rigid than the Grizzly or PM-25.
It seems either of the first 3 machines are going to make a good CNC conversion, but it would be nice to know what's the best machine and why.
Then there's the PM-728VT. This machine is about 100 lbs heavier than the PM-25, and about $1200 more expensive. It runs on 120V, has an OEM CNC ballscrew conversion kit, spindle speed kit, and DRO available for purchase directly from PM, plus it has a lot of great features, and a 5 year warranty. It seems to be the best machine in this class from what I can find. To convert it to CNC would require the OEM CNC Ballscrew kit and Speed control from PM, plus motors, electronics, and software from elsewhere. I believe this would be a very capable, rigid machine, but with all of the options it costs more than I'd like to spend right now. I'd love to hear what you guys think of this machine, good or bad.
With the 4 machines I'm considering, one of things steering me toward the Precision Matthews machines is that they have 36 month financing.
To favor quality over quantity, while staying sort of within budget, I'm considering picking up the PM-728VT with the deluxe CNC Ballscrew conversion kit, and speed control, and probably skip the DRO for now, then finance it over 36 months if I can get a decent interest rate.
It'll be a quality base that I can build on, that I believe will suit my needs for a very long time almost no matter what I want to build.
I can then sell my 3990 mini-mill to cover a good portion of the electronics and motors to finish the CNC conversion.
As budget permits and possibly not until I pay off the machine, I'll buy the DRO and other upgrades.
Doing it this way, I end up with the right machine from the get go, or, err, second go, and won't lose money upgrading the 3990 that I plan to replace anyway.
I may also decide that the PM-25/G0704/6500 is really the right size or you might too, or might decide a small Sherline is best.
I'm simply suggesting that if you can, buy the machine you want/need on the first go, and favor quality over quantity. It'll be cheaper and more enjoyable in the long run.
Have a great day!
Radical
