- Jul 26, 2011
- 4,139
The cutoff tool also needs to be perfectly VERTICAL. Those old,tapered cutoff tools are often not quite vertical in the tool holder. I always had to shim mine to get them perfectly vertical. If you don't do this, thin pieces you are cutting off can come out cupped from pressure the cutoff tool exerted while rubbing. A person on another forum had this problem,and was hammering his cut off parts flat,which isn't good practice. He got rid of the problem when I suggested his tool wasn't vertical.
And,it is a real pain to use the old fashioned cutoff tool holders in the old lantern tool posts. If you don't have an Aloris TYPE tool holder,save up and get at the least an Asian one. The best type is the wedge type,NOT the piston types,which are cheaper. Wedge type sucks the tool holder up against the tool block. Piston pushes it away,and jams it on the dovetail. That type isn't as rigid. Either type beats the lantern type,though.
