- Feb 1, 2015
- 9,901
A T7 Torx bit measures .070" across the "flats". I have used Torx bits to remove wallowed out screws where the conventional Allen wrenches no longer work.
You can't imagine the REAL meaning of jumbled . Homer buckets full , drawers full , containers full . I can't spread them out fast enough .It's all about fit. I keep all my Allen wrenches in a jumbled configuration and use the trial and error method.
some imperial set screws have metric allens. I bought a set of HF for fill and hate them because of that. So I avoid using them, but again they are for fill if I don't have the right size.I’m having trouble finding the right size for the set screw. After spending extensive time turning this flywheel, machining the set screw down, and then drilling and tapping a hole for it, I discovered I don’t actually have an Allen wrench that fits it.
It’s between a 1/16 and a 5/64.
1/16 was barely too small and 5/64 was a little too big. It’s a 6-32 so I don’t think it would be metric. It seems as though all the tiny sets I’ve been looking at don’t have anything in between those sizes. Anyone have an idea of what size I’d need and where to find it?
Early 80's for my first Chapman set #8900. Still have it.+ 1 on the Chapman sets . They've lived in my top drawer since 1999 .
Most likely the set screw is bad . I've run across bad ones over the years and just toss them .
You can also taper grind the oversize wrench to fit that screw if you need to , kind of like a " sock it out " tool . Or just buy a set , and use a tap wrench to tighten .
