Tricks of the trade when aligning things?
Mill with DRO is absolutely the best. I disagree with the :
from inside edge of one hole to the outside edge of the next hole
I’m very careful and have tried this most of my life out of necessity but it has always been less than satisfactory.
By far the best way to accurately measure hole distance is a Sorensen Center-Mike. It takes some practice but getting my measurements from the Center-Mike, laying out with Dykem, using an auto punch (for me way more accurate to start the punch marks with than punch and hammer, don’t know why) then transferring to mill w/DRO and using the Dykem layout as a hedge against brain flatulence, is my most accurate way.
Well thanks for that, on my mill it’s easy with the DRO. I do have a set of those Center finder punches with a range of diameters they are handy. I prefer the auto punch as well use it 90% of the time.
Well here is one trick I just used…..
I was mounting a wiper motor to the side of my mill on 4” standoffs about 5/8 diameter. On one end I tapped the hole in the Center, on the other end I offset the hole about 2mm. When things did not line up exactly as anticipated I simply rolled the stand-off until the hole lined up.
By plan?
Or discovery?
Just giving you a hard time;-)
Sent from my SM-G781V using Tapatalk
Actually by plan, I expected at least one of three holes would not be quite right because the three mounting holes had to be correct relative to each other but also to the ”center bore” that was not in the center of the three holes. In the end it runs almost perfectly true….almost but close enough.
In hindsight I could have attached the spindle to a scrap plate then drilled the three holes in the plate ( correct if necessary) and then used that as a template for my mounting block….next time.
Lots of ideas. I'll add my two cents.
If the part is accessible, I will measure distances between two holes by inserting tight fitting pins. Then I measure the diameter of one of the pons and zero the caliper. Next, measure outside to outside distance. The caliper reading is the center to center distance. If holes are different fiameter, it becomes more tricky. You have to measure both pin diameters, add them up, and divide by two for the average diameter, Then, with the caliper zeroed out, measure the outside to outside distance and subtract the average diameter for the center to center distance. Careful measurements will give you the center to center distance within a thou or two. For threaded holes, I use screws instead of pins. Screws have a relatively loose fit so I will use short socket head cap screws, tightening the down to the surface of the part and measure off the diameter of the cap. Shoulder bolts also work well. If neither is available, I will run a nut on each of the screws and tighten to to part. This helps to center the screw in the threaded hole. Finally, if a nut isn't available, measure outside to outside distance and inside to inside distance, taking up any loose play, and average the measurements to get the center to center distance.
A similar process can be used by measuring the holes with the inside jaws of the calipers. It is potentially less accurate than using the pins because care must be taken not to have the jaws set too deep in the holes as that will prevent you from measuring a true diameter or distance. When measuring the holes, you have to add the average hole diameter to the inside to inside distance.
Usually, distances are nice even numbers. Designers like to design like that. Check the dimensions in both inch and metric if you don't know the origin of the part. But don't assume that to be true without checking. I was fitting a new back plate to an Asian chuck and measured hole to hole distances to determine the pattern for the three bolt and found that the holes missed the perfect 120º bolt hole pattern by a half a mm. Measure all distances to get an accurate layout. I like to lay out the measured dimensions in a drawing for a sanity check.
When working with parts that can't easily be blueprinted, One method that give absolute alignment is to drill and tap 6the first hole and mate the parts by fastening them together with that hole. I align the parts for a good fit and using the second hole as a guide, spot the hole with a tight fitting drill, followed by the tap drill and tapping. Insert a fastener in that hole and move on to the remaining holes. It is more time consuming but it onsures a perfect fit even using hand tools. This process works well for dowel pins if you use a reamer for the final fit. If I am making both parts, I will make the first hole in the "pattern" piece for a tight fit for the fastener and drill the remaining through holes for the tap drill size. Then I drill all the tap drill holes, followed by opening up the hole to a clearance for the tap , and tap the holes. This process uses the clearance holes as tap guide and insures perfect alignment. Finally, I open the through holes to a clearance hole size for the fastener.
When blueprinting complex parts, I have spindle mounted microscope that can resolve to a tenth which I can use with the DRO to accurately blueprint a part. I have successfully used that to make gaskets for carburetors. It makes for a great optical comparitor. I determine coordinate points for all features, collect6ing as many as nec3essary, and locate the set of points in a drawing then I connect all the dots to make the pattern.
#17 a one tenth dial indicator and a sledge hammer.
(Avoid hitting the dial indicator)
RJ,
Thanks for that, I particularly like the tight fitting pins idea, I happen to have a full set of precision dowels so I can make use of them for holes < 1/2”. I’m going to try this method next time.
To add to RJSakowski, I use the pins if handy, but I more often use ball bearings. I have several lengths of 1/8" thick by 1/2" wide strips. They have a 1/4" dimple in one end and a slot running down them. I used a 1/4" ball mill. You can hold the strips or clamp them. If you use a digital caliper, you can measure on one ball, (or pin) zero out the caliper , them measure across them to get true reading. If using different sizes, them add them up and divide as stated above. I have multiple sizes going up to 1-1/4" diameter for less then $20. Several came from old bearings for free.
After learning of the Center-Mike I had to know more, so did a search. In addition to some descriptions, I found one for sale on Etsy in better condition than & at a lower price than what came up on eBay, so I bought it:
Etsy:
After cleaning and giving a coat of Renaissance Wax:
The box I had (yes, the instruction plaque isn't centered, but it does cover a blemish in the lid).
