- Aug 3, 2017
- 2,419
That half-ball is really a piece of work, isn't it. Perhaps you can find a ball bearing ball with a diameter between 11.5mm and 12.5mm (which includes ½") and proceed as I'd planned as one of my paths forward. Soft solder it to a length of brass or steel pipe, grind away half of it, then unsolder and hot-wipe the solder residue off. The solder should hold the ball well enough. I was planning to do the grinding by hand, quenching frequently to prevent the solder melting. You might well be able to do it on your surface grinder ... much finer control!
I've no idea how I can hold them, but I just picked up a bunch of 1/2" ball bearings on amazon, so I'll give it a go! I have no idea how I can hold it in the surface grinder... I wonder if 'boxing' it in on the mag chuck would work...
