- Oct 6, 2010
- 699
Thanks all for the suggestions. I was considering using a router for the motor. I have several, so wouldn't miss it for wood work. A spindle should be no problem. As Tom stated, it's all about the bearings. My primary objective is to focus on ID grinding. I am quoting a couple of parts where it sure would be handy. The part has a two lobed ID of 1.450 diameter with a 0.080 offset. Desired finish is 16 Ra. Since they are offset, honing is out, for at least the second one. So, I am thinking that grinding is the best way to go.
Bodine does make a nice motor that would be good to base a grinder on.
If your primary use is for finishing small ID bores then a quick and easy solution might be the use of a die grinder mounted on the tool rest. I have attached a copy of a Sears catalog that shows one they use to offer. Die grinders and plentiful and not that costly. I think HF even offers one similar to the Sears one.
Benny
