- Jun 23, 2019
- 87
I'm sure it's good if the Germans use it. However I don't speak Deutsch. Can you please put an American number on "good n"?I use German spec good n tight!
Yes, 43 years experience is better then any torque wrench. Here's my problem. I'm looking for a number. Many numbers would be better and I can take the average. However I'm beginning to understand that people don't use a number. They don't have a clue what the torque is and they don't care. They know what works. I'm good with that. ThanksUse a standard size 3/4" wrench and put the brake on . Tighten it up by feel . Never had an end mill pull out in 43 years . If it worries you , go with an end mill holder .
Well "don't have a clue" wasn't the way to put it. Don't need to know is better.I wouldn't say "they don't have a clue". Over the years most of us have gained enough experience to know what 40 ft. lbs. of torque feels like when using a standard 3/4" wrench. We may not always, or ever hit 41 ft. lbs. on the head exactly, but we know we're within a couple pounds either way.
As for the torque spec of 41 ft. lbs. on a 7/16-20 thread it's the number that will provide the most holding power without damaging either the internal or external thread. You can tighten it much tighter if you wish, but the down side is that it won't last. To my knowledge the drawbar in my Bridgeport is the original. That's 48 years of tightening and loosening it with out damage.
As for an end mill pulling out I've never had it happen on my machine.
