- Dec 31, 2011
- 92
One more. mounted on the dovetail spigot of an Atlas 12/36.
The base of the compound was reproduced in aluminum and drill rod used for pins to contact the steel dovetail spigot. I drilled and tapped the pins for "rescue removal" should they become stuck (paranoia) which they have not done to date. Porter Cable router run through router speed control. Also does fluting with any 1/4 shafted mills or router bits in aluminum or brass.
