Ok,,,, I got my motor for the grinder today. It is all set up to use and works fantastic. Runs smooth and quiet. Now I will tell you about it. It was such a crazy idea and I have been ridiculed ( elsewhere on the net) for even suggesting this, but I was fairly sure I could pull it off. The ideal motor for the grinder should have adequate power, 3450 rpm, lots of torque, and be small in size to be light weight. In searching for quite a while I ran onto the solution on eBay. A CHINESE WATER PUMP!! It is small. The housing is aluminum, the end bells are cast iron, it has ball bearings, it is 3450 rpm, it is 1/2 HP, it has copper windings, and it is light weight. Sounds like the perfect motor. Soooo... what is wrong with it you may ask? ..... Well, it has a pump built on to the front end. The end of the motor and pump are cast as one piece. It is NOT reversible and runs the wrong direction. Minor inconveniences, but important ones. It is a good thing I have a lot of experience with rewinding and rebuilding AC and DC motors.
You can see how small it is for a 1/2HP motor , it is really small as I am holding it in one hand.
This is the pump and motor. My first order of business is to tear it apart.
Now out to the shop and cut the pump off in the band saw.
There, now the front looks like any other electric motor. Firs problem solved.
These parts are now scrap!
Next , I lifted the one lead that is common to the run winding and the start winding and cut them apart. You can see the two windings welded to the yellow lead here. I cut the start winding loose and attached it to it's own (white) lead.
Next, I tied the leads back down with nylon cord and coated them with a half a bottle of clear fingernail polish to secure everything in place. ( LMAO, my wife is still trying to find her fingernail polish).
Now I have four leads coming out instead of three and the motor is now reversible. I added a start/ stop switch
The motor is ready to go and it only cost me $30.
It will get a coat of paint to spiffy it up.
