Just by looking at your hands...Yeah here in the states you must use a primer before the joint is glued, it's dyed purple so the inspector knows you used it.
And if you glue conduit (PVC) you must use the gray primer, if you use the purple you fail.Yeah here in the states you must use a primer before the joint is glued, it's dyed purple so the inspector knows you used it.
I've never seen gray primer, just gray PVC cement?And if you glue conduit (PVC) you must use the gray primer, if you use the purple you fail.
Glue primer on the pipework?
Because electricians and plumbers hate each other and so do the inspectors.That’s electrical conduit I assume. It’s still pvc, don’t know why it would fail an inspection.
