There are several guys on YT who say not to start out on MIG. Dunno why. Welding is welding…..
MIG is tricky because IMO, it all has to do with the electrode holder & the electrode (there are of course other factors). If you think about it like this, MIG is quite unique compared to TIG or SMAW: in TIG/SMAW (which are considered 'constant current') if you move the electrode away/to the joint, aka: changing the arc length (without doing anything else), you can clearly see the difference in the change of the arc; IE: with SMAW you can usually see the metal deposition go to crap if you increase the arc length way too much (unless you're using 6013s, then you can't see hardly anything because of the slag
With MIG or any wire-feed process, because the electrode (the wire) is feeding out of the electrode holder at a high and usually constant rate, the situation is much different IMO. If you increase the stick-out (contact tip-to-work distance) even just a little bit, the wire is still being fed at the same exact rate, so the metal deposition is still happening in a fairly uniform fashion and you can still see a molten pool, but the added CTWD causes a resistive heating effect whereby there is more voltage drop in the wire than there should be. The voltage drop in the wire needs to be kept at the appropriate level, so that the arc intensity and amperage at the weld pool is not decreased. It's not like TIG/SMAW whereby those are CC processes, and if you increase the distance from the electrode to the weld pool, the machine typically increases the voltage and you can see the arc flare out. MIG/MAG are 'constant voltage', so the typical scenario for a beginner using MIG/MAG is
holding too long of a stickout and not having a clue that this is affecting the voltage
and amperage output because the resulting weld bead can still look fairly uniform, yet is way too cold; it was hot enough to melt the wire feeding out of the gun, but typically not hot enough to melt the base metal and create a proper fusion between the parts intended to be welded.
So I agree with those YT guys IF the person that is starting to weld doesn't have that knowledge I specified above, or is not being guided by someone who knows what happens when you do things wrong. That's just my take on it of course.
