TIG is Hard
Janderso
Jeff Anderson
H-M Platinum Supporter
Mar 26, 2018
8,645
I've found I really need magnified vision to even attempt to get a reasonable result.
I bought the inserts at the welding shop. They help but I think I need more magnification.
I don't practice enough!
This is 18 gauge steel sheet. I finally have a respectable bead this morning after making a mess of things.
The other thing that's frustrating, I get shocked-buzzed when I touch the table with my arm. I put this pad down to help with that.
TIG is just so finicky, everything has to be just so. I have to be right in there to see and manipulate the tungsten so I don't dip. So far, only one dip today!!
Just killing time in the shop.
Your doing better than me. If you have exposed skin, your not getting "sun burn"? I use a leather welding jacket, so I guess I have insulation to the table. I'm still practicing at being bad :)
Looks like you're off to a really good start! Watch tons of youtube videos to get ideas of what to think of and most importantly, spend a lot of time actually welding!
TIG is just one of those things where you really need the seat time to start getting good at it.
I also find that it's extra important to have really bright lights so you can see better what you're doing.
I used to do a lot of TIG on stainless 303 and 304 mostly 16 gage pipe but also heavier parts, most of what I did was using a welding positioner with a device to steady my hand and always using a foot pedal to fine tune the heat. You don't say what gloves you use, you should be using thin "TIG" gloves for fine feeling and control of the torch.
I have to agree, thin stuff is difficult as it doesn't give you a lot of time to form a puddle before it just melts away. I originally learned to weld with OA, I have to resist the urge to pull the torch back a bit.
I've never had trouble with getting shocked. I ground clamp to my table all the time. What are you touching that is at the electrode potential?
That's what I'm using John.
I'm also wearing the welding sleeves to avoid getting sun burned.
I haven't tried stainless yet. I have quite a bit of stainless sheet scrap I can learn on.
I'm using 100% argon. OK for stainless?
Maybe I'll try out the 1/8" welding cards I bought for practice. This thin stuff is a royal PITA
