- Mar 21, 2018
- 1,716
Going to try some knurling on that brass piece, after I figure out how to set the diameter for the knurl pitch.
Don't bother with trying to set the diameter. The knurling tool will most of the time track in the groove from the previous revolution. Bump knurler or scissor type? Just remember to use lots of lube.
Next: steel. Enjoyed grinding the tools for brass. Steel tools seem a bit more complicated.
They're not really all that complicated - a little side rake, a little top rake and a little front rake (it will look a lot like your threading tool, except for the top rake and a small radius). Use an India stone to give yourself the small radius at the tip (~ 1/32" to 1/16") - you'll find that the grinding wheel is just too aggressive to put on a proper radius. Also use the stone to give yourself smooth surfaces where the tool will touch the metal - you'll get a better finish.
