I was taught that drag on the handwheel in high school/JR college shop to clean up the backside of the thread on the last spring passes, we also used the tried and true 30 degree setting of the compound, rather that the revisionist 29 1/2 degree setting that so many seem to think is better; as I have said before, all the journeymen in my apprenticeship shop used the 30 degree setting.It can also help to put some drag on the handwheel with one hand to take up any play.
That looks MUCH better! It almost looks like you know what you're doing.Confirming this group's suggestions, it appears I was catching the engagement just before the desired number, probably more than once. There are three engagements between the major divisions, and it is easy to engage the early one. Lessons learned, and thanks again !
