- Feb 23, 2016
- 467
I am learning how to make (external) threads on my lathe. Although I can rotate the compound to any arbitrary angle, once at 29.5 degree (or 60.5) orientation advancing the crosslide and/or compound will not result in the desired movement. My compound and toolpost can only be setup at 90 degree rotation.
So I need to keep the tool perpendicular to the z axis and advance in both z and axes with each pass s- let's say -10 thou in z and 17.3 thou in x.
Anyone has the same problem?
