- Dec 28, 2022
- 273
Hello all - I'm running into an issue where the left side of my threads are tighter than the right side, and I'm wondering what I can do to correct this.
(I am threading barrels for muzzle brakes and actions) I'm seeing this on both ends. Typically the last .100-.150 thou is too tight to continue to thread on and once I get the threads to a point where I can thread the mating device on, the beginning of the threads are pretty sloppy. Still within spec, but looser than I prefer. (2A+ fit)
When I do a taper cut test, I'm only out about .0006-.0009 over 6 inches so I don't think it's related to that. I'm not taking heavy cuts when threading, so deflection should be at a minimum. What else could I check?
Thanks much.
Thanks much.
