- Nov 9, 2013
- 790
You would be better off with something like this:
http://www.grizzly.com/products/4-x-6-Metal-Cutting-Bandsaw/G0622
Or the Horror Fright version:
http://www.harborfreight.com/horizontal-vertical-metal-cutting-bandsaw-93762.html
You realize that both of these are the same saw, right?
This saw has been around for decades under dozens of different brand names. While it isn't the best saw available, it can be carefully adjusted and tweaked to work pretty decent. I know a lot of guys here have them. I have one too.
The slightly under 4" diameter material limitation can be a problem if you're working with larger pipes, or angles that would bump into the saw's frame. With a good quality USA made blade, it will cut a lot of metal. It's not "the" answer, but is certainly a viable option.
They can usually be found used on Craigslist in the sub $150 range. I got mine for $45. At that price it's pretty hard to beat, and it's a great starter saw that will do some real work.
Cheers,
GG
