- Feb 7, 2014
- 90
Hi guys, I'm getting ready to build a set of exhaust headers for the race car and was thinking about getting a band saw for cutting the tubing. Anyone that's made headers will know why a band saw would be really handy. The mandral bends you can buy are never exactly what you need right out of the box. You have to cut multiple slices out of the radisus in order to make some bends "tight" enough and the opposite is the case when you only need a slight about of curve.
The last set I built I used my abrasive wheel chop saw. It works fine but what a noisey dusty, messy process! Even my good milwalki doesn't make cuts in tubing very straight. So then I would be stuck side wheeling/griding to get that perfect fit.
Harbor freight has a portable band saw. It has a really wide blade that doesn't bend much. I worked for a guy that mounted an aluminum plate to it so he could mount it in a vise. He's built at least 50 funny car chassis with it and who knows how many roll cages. The problem is it comes with wood blade and they don't even offer a 24 or higher tooth blade. They're available at home depot but it just seems like a big pain in the neck when for not much more I could get the cheap "regular" band saw.
http://www.harborfreight.com/9-in-bench-top-band-saw-60500.html This is their 9in saw. The reviews mostly say they wouldn't recommend it for cutting steel. I would agree that's no doublt true if you were trying to cut 3" thick flat stock with it. But I would think it would handle 16 gauge mild steel tubing?
What do you guys think about that saw for my project?
While roaming craigs list I noticed one that is a 10" but appears to be much beefier from the pic. Here's the link? http://flint.craigslist.org/tls/4504723256.html
I haven't even started building the flanges yet nor have I purchased any bends so I have some time to make the decision. I could just use the chop saw again but what a noisy mess! On the other hand other than this project I can't see a band saw getting used much at all.
Any advice would be greatly appreciated,
Wayne
Wayne
