- Oct 7, 2013
- 305
I figured out my problem with the apron. After trial assembling the apron, I neglected to completely disassemble it again before final assembly. In doing so, I forgot to re-install the ball and spring for the detent in the half-nut lever. Luckily, it was a very easy fix. All is well now. I should also note that it appears there is no "lockout" that keeps one from engaging the half-nuts while the power feed for the cross slide or carriage is engaged. I guess you just have to know not to do it. I will investigate this more, as I thought I remembered reading that there was a lockout. Maybe that was in my South Bend book.
Tim, as long as the cabinet is close enough to level that the coolant runs to the drain, you're fine. The lathe bed has leveling feet that give more than ample range for leveling to exactness. The only shimming will be to accommodate uneven spots in the shop floor (whenever I get another shop) to give the cabinet a solid footing and keep it from rocking. That's the problem with the feet I installed. They raise the cabinet about 1-1/2" and make it a little unstable. With the machine running I can feel it move the cabinet with vibration from the varidrive. I think it would be better all around to have it bolted to the floor. I'll only be in my current shop another couple weeks, though, so it won't be here.
