Cutting the grooves for the valve slide. I've found a lot of different methods and fixtures other folks used for doing this on the web. I decided to just rotate the head stock 45 degrees, hold them in the vise, and use an end mill. I don't have angle blocks or a sine bar so I used what I have to set the angle.
I just knew that old drafting triangle would come in handy some day.
After that and moving the vise it was just a matter of cutting the grooves. First the bearings.
Then the caps. When I checked the caps I found I must have missed a pass when I spot faced for the screws and the bosses were different heights, so I had to square up the mill again to fix that and then reset the angle and the vise. I'm getting good at indicating the vise.
Bearing caps done! The plans call out the thickness of the mounting tabs but not the overall thickness of the cap. Mine are just thick enough to interfere with the eccentric bearing. Rather than trim the point off of the caps I'll make a slightly longer valve slide post.
Then put it all together to see if it works.
Now I can mark the locations for the screws that hold the cylinder to the frame and get those drilled and tapped (once the tools arrive), and finally remove the frame from its centering fixture.
I feel like I'm on the home stretch.
Eric
