To make the helical focusser I decided upon a 1mm thread pitch cut at 4mm lead.
This gave me a 4 start thread of M1 pitch where 1 turn gave 4mm of travel.
The hardest part was getting the top slide perfectly aligned with the ways so 1 turn of topslide lead screw went exactly 1mm
I used the hand crank to turn the spindle,
First thread cut to depth then back to the start without disengaging the half nuts.
Advance the top slide 1 full turn (=1mm of travel) and cut the second thread
And continue for the third and fourth cut.
To cut the internal 4 start thread I kept the settings for a 4mm pitch but used an M10x1 tap silver soldered to a bar.
I opted to try this as all 4 starts are cut at the same time so I could use the part above as the test fit to get the correct dia and thread fit.
Again I used the hand crank and didnt disengage the half nuts.
A bit more work produced these parts
Running down they are the external barrel with the internal thread, an "0" ring seal, a brass retaining ring with 6 x M2 screws, the 4 start internal tube that screws inside, the eyepiece holder with internal brass ring so the clamping screw doesnt mark the eyepiece.
They fit together like so, as the threads are greased the "0" ring keeps the grease from coating the tube
The brass ring sits inside a recess of the eyepiece holder
I used the flat edge of a woodworking router bit to cut the recess
