The clips are done and the whole assembly holds together solid.
Now they are clipped together another problem has reared its ugly head, welding distortion.
The two side plates that the pivot will be bolted to do not sit parallel when bolted up, on one side the truss is slightly warped.
To solve this I made four exact sized spacers from some thick walled aluminium tube and bolted them together.
when turning the spacer tubes they got pretty hot from the friction of the steady and expanded.
I had to wait for each one of them to cool to ambient to get the real measurement and then finish off their length.
They came out to within 2 thou of each other. I felt that was close enough.
This has worked to get the side plates spot on parallel and square.
Now I will bolt the two trusses together using shims to take up the slack and keep them parallel.
Here they are just sitting at the top of where they must go.
After sorting out the central plates and re-aligning the vertical trusses I had to make a new bottom plate.
I first cut the half circle section out where the main support will fit with a jig saw which was not very accurate but I stayed inside the line.
Then milled it to size with a 4mm end mill in the drill press. (yeah yeah I know you shouldnt but it worked).
Then I smoothed the milled cut with a flap sander, it doesnt actually touch the table it just looks like it does.
Once this bottom plate was in place I could bolt the whole assembly back up and find the balance point.
To get a more accurate idea of where it should balance I added the glass blanks for the mirrors and more metal to take the place of the mirror cells and a package of the four secondary and tertiary mirrors and a couple of eyepieces at the top end.
It balanced 1/8 of an inch below where I thought it would have when I first planned it out. I felt good at that point.
But, we always have to have one of those, that 1/8 of an inch placed the central hole in the pivot just off the diagonal brace so I had to cut a small section out.
Bah humbug. Actually because there is a plate bolted all around that section I dont think it needs the diagonal at all so I may cut it completely out once I tear it all down again or weld in a bridging section.
