I didn't like the feel of the QCGB shifting when I tried moving the levers after I had it off the lathe, so I already knew it was going to get a full teardown. The levers felt sticky but overly loose and kind of jerky when they did move. After looking it over carefully, I started loosening all the locking grub screws and then pulled it all apart. Some of the parts needed to come out first to get out of the way before others could be removed. I'm sure there's a "Best" way to disassemble it, but I just took my time and kept at it till I had it all apart. The last bit to come off was the data plate on the front. To remove that I tapped the little screw rivets (not sure of the exact name for them) from the inside to raise them up a bit. Then I carefully grabbed under the heads with a pair of side cutting pliers, and gently wiggled them out.
The shaft ends all look like they were run without oil for a while at the ends where they ride in the bushings. The bushings didn't have any oil holes in them coming from the oil cups. I'm not sure if that was an oversight when someone may have replaced the bushings in the past, or the wear filled the holes with metal flakes. Either way, it looks like I'll need to get all new shafts and bushings to get this unit back up to 100% condition.
I'm considering reassembling it as is for now until I can find (and afford) the needed replacement parts. I'll definitely have to open up or drill the oil holes in the bushings first though.
My phone was on the charger in the house so I didn't get any pics today.
