Thinking about the Edge Technologies test bar, it is important that the lathe be aligned to not turn a taper without the tailstock (two collar or RDM test) . Otherwise, any error would have to be considered when using the bar to align a tailstock. If the bed has a twist, the tailstock would only be aligned at the tailstock position where the test bar was used.
Also, if the tailstock is twisted so the axis of the quill isn't parallel to the spindle axis, the amount of quill extension should be the same as where the alignment was done.
