I checked my tailstock alignment on my mine by using 2 mt3 dead centers and making sure the tips meet. Is this not sufficient?
It is pretty hard to be sure the ends meet to within .001"I checked my tailstock alignment on my mine by using 2 mt3 dead centers and making sure the tips meet. Is this not sufficient?
Accuracy of the tube in a runout sense is of no consequence. All that is important in the end is that the drilled centers and the cut collars are cut concentrically and with minimum taper for easier measuring. The tube is only a structural element, there are no important dimensions for its purpose. The sequence of operations uses the length of the test bar to reduce any possibility of the test collar faces being tapered. The long bar reduces that small error by a large magnitude. Still, I dialed them in with the 4 jaw as good as I could. I do not know if using a 3 jaw with a few thou runout would make any noticeable difference in the end product. Try it and report back!Edit: By this- "Mount the tube deep into the spindle, deep enough for just enough to stick out to turn the O.D. of the plug. " I assume you mean using a 4 jaw chuck and dialing it in to the highest accuracy? Or does it not need to be that accurate since the final cuts are done at the tailstock end?
R
Yes Sir I will!Accuracy of the tube in a runout sense is of no consequence. All that is important in the end is that the drilled centers and the cut collars are cut concentrically and with minimum taper for easier measuring. The tube is only a structural element, there are no important dimensions for its purpose. The sequence of operations uses the length of the test bar to reduce any possibility of the test collar faces being tapered. The long bar reduces that small error by a large magnitude. Still, I dialed them in with the 4 jaw as good as I could. I do not know if using a 3 jaw with a few thou runout would make any noticeable difference in the end product. Try it and report back!
Tubal Cains method looks quite simple but I am totally confused about how he did this? He first machines the MT3 part in the spindle. Then he removes it and places the MT2 arbor in the spindle? How is this possible? Did I miss something?I've done Lyle's (Tubal Cain) method using two drill chuck arbors to get my TS aligned. Highly recommended. Unlike being restricted to test bar length, you can position your TS anywhere along the bed and measure alignment.
Robert
Thank you. I missed that. That would introduce the small error of the sleeve I suppose. Still seems like a good method.He machined the MT2 first using a sleeve & machined the MT3 second. You can see the sleeve better when he removes it at 5:32.
