Yes it is at a low (can't remember what mine is set at) low pressure.Is the fog buster tank pressurized?
I have tried several, My favorite is "Metal Working Fluids, TRIM MicroSol 685", I bought it for the flood cooling and it works well in my mist system.Anyone care to share their favorite soluble oil brand/supplier?
I'll want a gallon at most, a quart would get me started. To avoid big shipping charges, something sold in Seattle would be most excellent unless someone knowss a reseller with free shipping?
I use HSS cutters most often with occasional carbide. Small/old/clapped-out mill and lathe. Have only used cutting oil applied with a brush or squeeze bottle until now. Leaning toward the LubeCube (thanks @mksj!)
I have a small air compressor that lives next to the mill already.
Thanks,
Mark
Many thanks for the stupdisimpletools link. I found two (2) and probably more to come, additions to my shop. They have some well thought out and designed tools on the site.Alternatives often require air/compressor to pressurize the delivery system. Also depends on the application if this is for a mill or a lathe. Various coolants available, I use a water soluble oil emulsion solution which works on a wide range of materials, my primary concern was improved cutting performance, minimizing rust and low volume. A Fogbuster type system works on low pressure for both air and fluid lines so the end result is more spitting fluid as apposed to aerosolization. I made my own system and both lines have separate pressure regulators and solenoid valves. There are also separate needle valves to set the flow, I run very low pressures these days. Cost to make your own system is probably under $100. Alternative is below. At one point I tried Kool Mist solution in my bandsaw but had a lot of rust as well as going bad in the tank.
LUBE CUBE
Our HVLP fogless coolant sprayer that delivers a precisely targeted spray to the cutter and work piece without finely atomizing toxic coolants - substantially reducing coolant waste, lubrication over-spray, and hazardous fogstupidsimple.tools
