- Jun 12, 2014
- 5,076
I believe it is Kool Mist #77, I have a bunch of it but had some rust issues as well as tank life issue. Maybe at higher concentrations and light applications may be OK. I have been using KOOLRite, current version is 2290 in a 10% concentration, I have also seen Trim Microsol 690XT recommended and it is available in a 1 gallon size. KOOLRite use to be available in 1 gallon but now only 5 gallon. Trim Microsol 690XT gets some very good reviews and seems to be more readily available at a reasonable price for 1 gallon which should last a very long time. Recommendation of KOOLRite and Trim is based on use with different metals, if primarily aluminum then are other options. A little bit of coolant goes a long way in a manual milling/turning application. I find it more impactful with milling vs. turning. One last thing that I have seen mentioned is to use either RO or distilled/demineralized water may also help reduce rusting and increase duration of use. The KOOLRite lasted over a year when I used it for flood coolant in my bandsaw, the Kool Mist went bad in about 3 months.
