Implementing some changes. Tapping the second hole, 1/4 - 28.
A 1/4 - 28 bolt installed.
This is rough and being done mostly for my education. We grow too soon old and two late wise. I've decided to machine a bit holder in the opposite end of the steel, there is plenty of meat to do so. The cut from the side is very effective in relieving tension, it is very easy to trap the the bit by using very light tightening pressure on the 1/4" screw. You can see where the holder has rubbed, I don't know the best solution to this problem. Currently thinking it would be best to remove the offending metal on the vertical, rather than the horizontal surface.
Bob, your suggestion is excellent for those that have broaching capability. I do not. On the second attempt, I will make the hole .296". Make the longatudinal slit, with the cross slit about 1" behind the hole. This will remove tension, allow easy insertion of the forming bit and the press to do its thing. Will use two 5/16" clamping bolts, one top, one bottom. Milling will be a copy of this effort, unless Niel has some suggestions.
Bill
Bill
