Niels, If you didn't try, you would never know if you could do it. Maybe if you re think the process, you may be able to get it the second time around. I have to ask why the large hole behind the cutter? Buy the sounds of it , your working without a milling machine too. If that's the case, it certainly would make many jobs very challenging to say the least. I still use the same design you come up with years ago, and have not seen any reason to improve on it. But, that could change, depending on what you come up with. Im sure you will tackle the job with a different approach, and have success, its only a matter of time.
