- Nov 12, 2014
- 169
I'm looking for advise on drilling the end of the ram on my arbor press. The ram is 2" square and 27" long. I want to drill a 1/2" hole 1.25" deep in the end of the ram for holding tooling. I was hoping to mount it in my drill press. However after lowering the table, I only have 24" between the table top and the chuck. Add a short bit and down to 22". How would you go about drilling this hole. I can move the table to the side and use the base but but then the ram would have to be raised closer to the chuck, and then figure out how to securely hold it steady for drilling. I also have available in my shop a 10" SB Lathe but don't think I have a way to spin it to drill. All ideas and suggestions considered.
