If I'm not mistaken the head articulates on the Clausing whereas on the HF it doesnt. Also I'm pretty sure the leadscrews are something like 8 tpi on the HF machine
It doesn't look too tricky and will definitely be needed. When I pick it up I will definitely keep everyone posted.I'm not sure how much trouble it would be since I didn't do it, but I would think you can remove the knee without too much trouble. That would probably knock off another 50-60lbs. It would certainly make the column a bit less awkward. Other than that everything else was a load of 100lbs or less, not too bad for one person, and should be no problem with two.
If you buy this one, I'll be very curious to know how it works out. I have limited height in my shop so this size mill was an ideal size for me and I spent some time trying to find out about these HF mills. I was not able to find any comments on them good or bad which surprises me because it is a really nice size to bridge the gap between the larger mill/drills and knee mills like Millrite or the ubiquitous Bridgeports.
Even if it was a complete piece of junk, you would think people would comment to say so.
Good luck
I got a very similar Grizzly 6x26 and like it a great deal. for that price you can't go wrong! Work envelope isn't huge, but within it the mill is very capable. I certainly wouldn't want to get rid of mine, fits perfectly in the limited space I have for it.
A DRO would be a future thing but I can definitely see the advantages even over a 10 pitch lead screw.8 tpi means each turn of the handwheels moves the table by 0.125" which is a little less convenient than 10 tpi would be (0.10 per turn)
Non-issue if you have a DRO installed
Looks like the head does tilt but it requires loosening 4 bolts
You sir, are a bad influence.Go grab it. Does that help.
