7milesup asked about cutter sharpening on a surface grinder. This is the setup I made for woodworking shaper and router cutters.
There's a 3/4" arbor I use for 3/4" bore shaper cutters and 1 1/4" bore cutters with a sleeve. There's a router chuck for 1/4" and 1/2" shank router cutters and 1/2" bore shaper cutters with a stub spindle.
The base has a dovetailed slide made from milled and ground 1/4" steel plate. It's set at a slight angle so sliding 0.001" advances the depth of cut 0.0001". I find 0.0003" to 0.0005" is a good grind.
The arbor turns in these composite bearing blocks. It's ground for a very snug fit, and I like the action. These aren't high precision bearings, and there is more runout in the arbor than I'd want to grind metalworking cutters; but it works well for this. I've since added an extra brake on the arbor.
Mouldings are a big part of my woodworking. When I got this grinder working, I erased years of embarassing, haphazard sharpening on some of these.
The curved details on this little round table are done with small diameter, very sharp steel cutters. They cut delicate parts with minimum cutting force, and they get in and out quickly on the concave edge cuts. This will be ready to varnish in a couple days.
